Lowering gear ratio from 5.38
Ckreklau
Minnesota
This is probably a subject that has been talked about way too much so I apologize in advance, I have 2024 roxor 2.7l motor/5.38 gear ratio in axles. Is it possible to switch out the ring and pinion gears to a lower ratio? Maybe 4.10/3.73? Is there a kit you can purchase to do so without having to pull everything apart on the axles? Goal is 55mph at around 2000-2200 RPM engine range. Stock drivetrain 2 years in, this machine has done everything I have asked from it, from plowing snow to getting to fields with parts and tools. So very happy with it, just wish a little lower engine RPM and highway speed.
Only complaint is that I have had to replace fuel filters (2000 miles) a few times.
Wish list is if someone breaks the OBDII port and my tablet would be able to display full engine/diagnostic functions...
Thanks for your time!
