2019 ROXOR CLASSIC II ELETRICAL ISSUES HELP!
TRISTAN
KERVILLE TX
Having an issue with my Rotor. It will not crank. I do not hear a fuel pump nor does the digital part on the cluster work. I have confirmed that there is no ground going to the fuel relay under hood or the starter relay under the hood. when I jump those 2 to ground it will then crank and the pump comes on but will not start due to the injectors not pulsing I believe. Any insight on what to do would be much appreciated. When I jump the fuel relay and turn the key the pump comes on but will not turn off until I take away the ground. The cluster lights up but the screen that shows the odo is not lit and the needle does not move when first turning the key. Please provide any ideas as I need this thing fixed. Thanks in advance!
